Activity Forums Compression Techniques The old flv vs H.264
  • The old flv vs H.264
    Posted by Vince Becquiot on October 9, 2009 at 9:42 pm
    After spending a couple of weeks coding H.264 fall fallback pages for client previews, I fail to see better quality in H.264 encoding vs flv at bit rates below 1 Mb/s, meaning most web encoding.
    In fact the H.264 (encoding out of QuicktimePro) suffer much more in motion areas than Flash encoded with On2. My comparisons are mostly at 900/1Mb/s.
    Any light on this?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
    Daniel Low replied 16 years, 11 months ago 3 Members · 5 Replies
  • Craig Seeman
    October 9, 2009 at 10:59 pm
    Apple’s H.264 is HORRIBLE by modern H.264 standards.
    MainConcept (Squeeze)
    Dicas (Episode)
    x264
    Matrox CompressHD
    All do better H.264 encoding.
  • Daniel Low
    October 9, 2009 at 11:04 pm
    [Vince Becquiot] “In fact the H.264 (encoding out of QuicktimePro) suffer much more in motion areas than Flash encoded with On2. My comparisons are mostly at 900/1Mb/s.”
    Encoding out of Quicktime pro is crap. You need to use a dedicated encoding application. H.264 is way better than anything from On2 can spit out, if done correctly.
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
    “We and Apple are neck and neck and we’re chasing the two
    other players,”
    Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
  • Vince Becquiot
    October 10, 2009 at 2:30 pm
    Great, I had used After Effects as well which yielded to similar results so I was led to think that was an expected quality, I will give Squeeze a shot, thanks for the insight.
    Vince Becquiot
    Kaptis Studios
  • Vince Becquiot
    October 10, 2009 at 10:05 pm
    Gotta say, the squeeze export was like night and day.
    Thanks !
    Vince Becquiot
    Kaptis Studios
  • Daniel Low
    October 10, 2009 at 10:17 pm
    As we expected.
    other players,”
