Activity Forums Apple Final Cut Pro Legacy The Ol’ FCPHD Missing MPEG2 thing…
  • The Ol’ FCPHD Missing MPEG2 thing…
    Posted by Leanne Cole on January 18, 2006 at 9:36 am
    I’ve read all the posts… so the question is,
    has anyone figured out how to get the MPEG2 option back in the export quicktime conversion window in FCP5?
    I’ve copied accross the QTMPEGExport.component from an upgraded machine that still has it workin, and now it comes up with an error saying something about the SERIALIZATION in DVD studio pro. I dont like it.
    and i dont like compressor. I’ve got artifacts flyin all over the place.
    who would like to help?
    Leanne
    Leanne Cole replied 20 years, 8 months ago 2 Members · 3 Replies
  • Walter Biscardi
    January 18, 2006 at 11:17 am
    [Leanne] “I’ve read all the posts… so the question is,
    has anyone figured out how to get the MPEG2 option back in the export quicktime conversion window in FCP5?”
    You don’t, you use Compressor.
    [Leanne]
    and i dont like compressor. I’ve got artifacts flyin all over the place.”
    It’s the same MPEG-2 compressor that would have been in FCP if it was there. I.e. Export > Quicktime Conversion > MPEG-2 would yield the exact same results as using Compressor since it’s the same processor.
    Go in and tweak the settings or purchase BitVice to get extremely clean compression.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Walter Biscardi
    January 18, 2006 at 11:19 am
    You don’t. Use Compressor.
    [Leanne] “and i dont like compressor. I’ve got artifacts flyin all over the place.”
    Then change your settings within Compressor. It’s the exact same compression tool that would be used within FCP so you’re not losing quality over the “old method” by using Compressor. I.e. Export to MPEG-2 in FCP would yield the same results as the MPEG 2 in Compressor with the same settings. It’s the same MPEG-2 compressor.
  • Leanne Cole
    January 19, 2006 at 1:02 am
    Thankyou for your advice… BitVice hey… i’ll look into it.
    and yes my compressor settings do need to be revised.
    Leanne.
