Activity Forums VEGAS Pro “The Number of Channels is Not Supported”
  • “The Number of Channels is Not Supported”
    Posted by Tracy Holland on January 28, 2012 at 7:00 am
    Hi there,
    I have been importing several AVI files into my Sony Vegas Platinum 9.0 no problem then suddenly some won’t be imported and a message comes up saying “None of the Files Dropped on Sony Vegas Platinum Could Be Opened” and if I try to directly import instead of drag and drop, it says “The Number of Channels is Not Supported”. I’ve downloaded every video and audio codec I can find and finally got one to import but the rest will not. I noticed the difference between two files, one that is in and one that won’t, when I click Properties and check the differences, one of the audio codecs is Lame MP3 and the other is AC-3 CM. The one that works is Lame. I tried downloading a Lame codec as well as the AC-3 but I’m at a loss – nothing is working. I haven’t found this problem many other places online and I have no idea what to do. If it’s more than a simple process, please explain in detail as I’m not very familiar with the details.
    Thank you so much!
    Matt Carlson replied 14 years, 7 months ago 2 Members · 1 Reply
  • Matt Carlson
    January 29, 2012 at 1:26 am
    Vegas does not import AC3 in any form no matter what codecs you have installed (although you can render to AC3.) It is a pure license agreement thing. You have to convert AC3 audio outside of Vegas first with something like AC3 Pro.
