Activity Forums Adobe After Effects The motion path is not visible
  • The motion path is not visible
    Posted by Achim Siegert on November 10, 2008 at 10:37 am
    hello ,
    i got a problem:
    the interpolation path is not visible !
    i set a number of keyframes in my layer and animated the position, but the motion path between the keyframes is not visible even i selected the layer . i already checked the presettings.
    check the image link “bewegungspfad.jpg” ! sure anybody knows ?
    thanks in advance !
    Eric Sanderson replied 17 years, 10 months ago 2 Members · 1 Reply
  • Eric Sanderson
    November 10, 2008 at 5:26 pm
    You have to make sure the select of the “position” of the layer to get it to show up, not jsut the layer itself. If that doesnt work that try hitting apple/cntrl+shift+H, you may have accidentally hidden all your lines, but actually from that image that doesnt look like the case so if neither of those work than ya got me.
