Activity Forums Maxon Cinema 4D The most efficient way to load a background image…
  • The most efficient way to load a background image…
    Posted by Michael Munkittrick on May 15, 2006 at 6:37 pm
    Hi again. I’ve been trying to model a car based on a provided blueprint but I am finding that I must map those blueprints to a plane or else they aren’t visible.
    Is there another way that the image can be added as the background without having to assign it to an object?
    Michael Munkittrick
    Gainesville, Florida USA
    Chris Smith replied 20 years, 4 months ago 5 Members · 4 Replies
  • Adam Trachtenberg
    May 15, 2006 at 7:28 pm
    Yes, you can load bitmaps directly into the orthographic viewports. Doesn’t work in the perspective viewport for obvious reasons. Go to the viewport’s Edit menu and choose “Configure”. Now click on the “Back” tab in the viewport properties.
  • Yussef Cole
    May 16, 2006 at 2:55 am
    Additionally, if you want to be able to see your ref images in perspective mode, simply apply them to plane primitives of equal dimension and set them up carefully so they align with eachother.
  • Heriberto Levin
    May 18, 2006 at 12:23 pm
    shift+v on supported viewports (no perspective)
  • Chris Smith
    May 18, 2006 at 2:05 pm
    For reference, using the Back setting of the orth views is best, but don’t forget using the “Background” object for the perp view.
    Chris Smith
    https://www.sugarfilmproduction.com
