Activity › Forums › Creative Community Conversations › The missing Source Window
Posted by Dominic Deacon on October 10, 2011 at 11:41 pmJust curious as to how people are getting by without a source window. It’s seems to get talked about a lot less than other missing features. Multi-cam, OMF and EDLs get a lot of coverage but I’ve always assumed they would be added eventually. It’s the missing source window that got me to drop Final Cut. I can’t imagine editing without one.
I imagine can get by without one if you primarily edit documentaries or interviews but most of what I cut is drama. The source window is vital for eyelines or for matching positions when cutting from wides to mediums etc. Basically I need to be able to see two shots at once constantly.
Has FCPX got a feature I’m missing that makes this not an issue? I understand it has a Trim mode but I’ve never found them very intuitive. I'[ve always prefered to do everything in the source window or on the timeline.
Walter Soyka replied 14 years, 11 months ago 18 Members · 34 Replies -
Shane Ross
October 11, 2011 at 6:17 amYou aren’t alone. The missing VIEWER is yet another HUGE chunk of missing stuff that makes FCX not a viable option or me as well. Yet another example of a fundamental flaw in design, and how the engineers have NO CLUE about the tools that editors need and use. Sorry, that small scrubber window doesn’t cut it…even if I can finely tune my in point. I need a larger window in order to see what I am doing…I need a side-by-side comparison on many occasions.
Shane
Read my blog, Little Frog in High Def -
Ben Scott
October 11, 2011 at 8:51 amtry
- turning off skimmer
- display clips as a list
- use command 1 or 2 to toggle whats on the viewer
only thing I see as a problem for matching is ganging is missing which is essential for reconforming edits
for eyelines Its awkward that you cant turn off mark in and out when in events browser and the skimmer is off thats why jkl is probably better in that situation.
Rafael Amador
October 11, 2011 at 10:33 amFor me that’s enough to reject FCPX.
A source and a program window is the minimum to consider a system as pro.
Even the times of the U-Matic LB we had two monitors.
rafael -
Ken Pugh
October 11, 2011 at 1:01 pmI spent many years editing on Media 100 with its single media window, so I was very used to this style of editing, switching between source and record in the same window, so I know it can be done. Despite this, when I switched to FCP it was a huge liberation having both source and record windows active at the same time, I could never go back.
I wonder what’s the logic behind one screen? Is it so the software can work more effectively on single screen systems, like the iMac range? To make room for all the metadata? Useful as it is, I’d rather edit from pictures than metadata….
Ken.
Andrew Richards
October 11, 2011 at 2:01 pm[Ken Pugh] “I wonder what’s the logic behind one screen? Is it so the software can work more effectively on single screen systems, like the iMac range? To make room for all the metadata? Useful as it is, I’d rather edit from pictures than metadata….”
Probably a screen real estate thing. However, with two displays there is plenty of room, and the Trim tool shows a fleeting glimpse. I think they ought to have a persistent second viewer as an option for users who have the pixels available and need to see side by side images (though I have defended the lone viewer in the past, I’ve come around on this issue). Surely there must be some sort of second viewer in the cards with the upcoming multicam feature. Dare we hope for two birds with one stone?
Best,
Andy -
Walter Soyka
October 11, 2011 at 2:56 pm[Andrew Richards] “Probably a screen real estate thing.”
And yet many complain about gratuitous chrome. Also, when FCP v1 was released, most screens were 1024×768. Even the smallest MacBook Air today has 33% more screen real estate than that.
My guess is that the loss of the source monitor was driven by the design decision to try to simplify or streamline the NLE’s interface by making it more contextual: since you can only shuttle or interact with one viewer at a time, you should only show one viewer at a time. The two-up then appears in context only for editorial operations that explicitly require it.
Apple isn’t alone here. Smoke used to work this way, too, and many Smoke editors still use the single viewer. It is worth noting that Autodesk added a source/record view some time ago. Hopefully Apple will, too.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Olof Ekbergh
October 11, 2011 at 4:27 pmMedia100 also finally added a second viewer, after years of requests.
I think a second viewer is great, but not all the time. It would be nice to be able to have one like M100 does now, open it when you need it. It would also be nice if it had the capability of keeping multiple screen shots, possible from a popup window for CC etc.
Olof Ekbergh
Bill Hall
October 11, 2011 at 4:38 pmI still can’t help but by into the “it was designed for a touch interface” conspiracy theory. If that is the case screen real estate concerns make sense. You just don’t have much working room on an iPad and I imagine they are looking to make a seamless port.
This in no way makes it a good idea.
Walter Soyka
October 11, 2011 at 4:49 pm[Bill Hall] “I still can’t help but by into the “it was designed for a touch interface” conspiracy theory. If that is the case screen real estate concerns make sense. You just don’t have much working room on an iPad and I imagine they are looking to make a seamless port. “
I agree — the interface does feel very touchable, and that would certainly explain the usage of space in the UI design. You have to leave room for much larger targets in a touch system than you do in a mouse-based system. Resolution matters more in terms of physical space (since the size of your fingertip is fixed) than it does in pixels (where the tip of the cursor is always 1px).
Walter Soyka
David Roth weiss
October 11, 2011 at 4:52 pm[Andrew Richards] “I think they ought to have a persistent second viewer as an option for users who have the pixels available and need to see side by side images (though I have defended the lone viewer in the past, I’ve come around on this issue).”
I think you must have missed a dose of the Kool Aid. 🙂
Next, you’ll be wanting tracked audio.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comDon’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1POST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
