Activity › Forums › Adobe Premiere Pro › The miracle of Vista 64 ?
  • The miracle of Vista 64 ?
    Posted by Vince Becquiot on April 14, 2007 at 12:31 am
    I know we’ve talk a lot about the pesky memory leaks in PP2, and it does seem after a few experiments on my side, that it has vanished on a core 2 Duo, Vista Ultimate machine. With a 2 hour project, Premiere is actually staying at a steady 1.3 GB of ram. This is a DV project however, I haven’t yet pushed a DVCPro or True HD project here.
    Anyone else using Vista Ultimate?
    Cheers,
    Vince
    David Cherniack replied 19 years, 5 months ago 3 Members · 4 Replies
  • Atomic Blister
    April 14, 2007 at 2:59 am
    Actually I don’t have any memory problems either but I am running Windows XP Pro. I think it is an Intel issue maybe. Everybody who complained so far had an Intel machine.
  • David Cherniack
    April 14, 2007 at 9:46 pm
    Dual Opterons here with 3GB of ram. Lots of memory problems with 2.0. Anyone who hasn’t seen them just isn’t doing complicated enough projects. Hopefuly CS3 with or without Vista will solve the problem.
    I’m about to start a two hour documentary. I don’t know whether I’ll try anything more than a project per act, though. The save time on a large complicated project would just be too long.
    David
    AllinOneFilms.com
  • Vince Becquiot
    April 15, 2007 at 3:44 am
    David,
    The reason for my post, was that those same projects were seeing leaks on XP, (also on a dual Core, but 32 bits)
    The memory has remained steady on this new machine, which is why I’m wondering if Vista / 64 bits may have somehow solved that issue. I’m sure it will have its limitations as well.
    Vince
  • David Cherniack
    April 15, 2007 at 10:30 am
    Hi Vincent,
    My post was in response to Atomic Blister’s suggestion that the problem may have to do with Intel CPUs.
    The way I understand it Vista, either as 32 or 64 bits, offers a different addressing scheme to XP and more memory is available to 32 bit programs. Even with XP64 PPro seems to work better.
    This doesn’t help those of us running Axio however which only works with XP32 in its present version.
    David
    AllinOneFilms.com
