Activity › Forums › Apple Final Cut Pro Legacy › The MaxConnect internal hard disk drive mounting solution……
  • The MaxConnect internal hard disk drive mounting solution……
    Posted by Tasos Papazoglou on November 28, 2005 at 5:52 am
    Can this be used for editing in FCP 5.0 and Motion 2. With the speed tests they posted you can use this solution to edit uncompressed HD footage. With a price range under 2k for 2 Tbytes, it seems to good to be true. Any comments?
    Regards,
    Tasos
    Justin Ferar replied 20 years, 10 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    November 28, 2005 at 12:06 pm
    It’s a kit that allows you to add more SATA’s … probably just fast enough for HD if stripe them *one stream only* all and fill it to the gills, but that price doesn’t include the drives… so add another 2000 or so for that… I’d look elsewhere because I really don’t think that the cooling system in your Mac is up to it… I hear that internal systems work OK, but there sure are a lot of drives cranking inside there with this creating a LOT of heat, and it will in no way be the fastest solution for HD… Huge System’s 4 gig Fibre channel arrays would simply blow the doors off this solution for example… But cost a more. (ya get what ya pay for here).
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jerry Hofmann
    November 28, 2005 at 12:08 pm
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=8&postid=873599 leads to a used SCSI array which would be about TWICE as fast as the SATA array you are looking at. It will achieve 300 MB/Sec where the SATA will probably run at about 160 MB/sec or so.
    Jerry
  • Gunleik Groven
    November 28, 2005 at 12:48 pm
    I use an external box (homemead stuff from a PC cabinet with power) to run a RocketRaid 1820A external SATA RAID.(PCI-X)
    I get around 350 as a stable data-stream with 8 disks (400 GB WD’s with 16 mb cache – 7,2k disks)
    But I doubt I would put all those disks inside my G5 from the same reasons as mentioned above. The box has 3 fans and have been running without a hickup now for almost 3 months. Needs a separate room, though, due to extensive noise…
    I think I paid roughly = 2500 – 3000$ for the 3.2 TB setup in Norway.
    So far – just good experiences.
    Gunleik
  • Jerry Hofmann
    November 28, 2005 at 1:09 pm
    Yeah, with 8 disks you should be runnning pretty fast, and I agree that the external solution is a ton better… but the internal solution above only involves 4 drives (lots slower no doubt)…
    Jerry
  • Justin Ferar
    November 28, 2005 at 7:34 pm
    I’ve been using the system with 4 drives (Maxtor 300 GB) striped as a single RAID for about 6 months now, plus the boot drive. Honeslty I was worried about the heat but I can tell you that in my G5 dual 2.7 it has been a total non-issue. I only edit DV but I render as much as anyone- often an hour straight and the fans only come on intermitently.
    For DV you can’t beat it.
