Activity Forums Adobe After Effects The math behind blending modes
  • The math behind blending modes
    Posted by Chris Mellor on February 21, 2013 at 10:38 pm
    So I have been trying to figure out exactly what’s going on when changing the blending modes between layers. To do this, I am looking at the RGBA data (set to Decimal in 32bpc) in the Info window while moving my mouse about the canvas.
    So far, my theories were correct as to how “Multiply” and “Add” get their name… but I came across a much more fundamental question. Rather mindblowing in its simplicity.
    How is AE calculating the opacities of two overlapped images?
    The example I have been working with is simple: two solids with Opacity=50% overlap to create an overall opacity of 75% (.75 floating point).
    I am not understanding the equation of .5 + .5 = .75
    Furthermore, it seems .3 + .3 = .51, .75 + .75 = .9375 etc etc.
    I’m just curious what the math is behind this calculation.
    -Chris
    Darby Edelen replied 13 years, 6 months ago 4 Members · 4 Replies
  • Vishesh Arora
    February 21, 2013 at 11:44 pm
    Chris
    This is related to Zeno’s Paradox. You can read about it from here:
    A lead developer on the After Effects team once described the program’s opacity calculations as follows: Imagine you have a light which is 1, and place a 50% transparent filter (say, a sheet of vellum) in front of it. Half the total light is permitted through the vellum (0.5 * 1 = 0.5). Put another 50% transparent sheet of vellum on top of that. Now half of half the light shows through (0.5 * 0.5 = 0.25). You can theoretically repeat ad infinitum without reaching 0% light transmission, at least in a pure digital environment.
    For more info check this.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Todd Kopriva
    February 22, 2013 at 12:51 am
    See my answer to your question here:
    https://forums.adobe.com/message/5092658
    After Effects team blog
  • Chris Mellor
    February 22, 2013 at 1:43 am
    Definitely needed to take a step back and think that through logically. Thanks for the help, everyone!
    -Chris
  • Darby Edelen
    February 23, 2013 at 1:19 am
    The Normal blend mode is a standard alpha blend. The reason the colors don’t quite make sense in a simple mathematical relationship is because you’re not considering the alpha values.
    If you assume ‘A’ is the top layer, ‘B’ is the lower layer and their alphas are ‘a’ and ‘b’ respectively then the resulting color is:
    A*a + B*b*(1-a)
    Opacity modifies the alpha of the layer.
    Darby Edelen
