Activity Forums Adobe Audition The MagicNumber: Converting 29.97 audio to 25fps (Stretch and Pitch process)
  • The MagicNumber: Converting 29.97 audio to 25fps (Stretch and Pitch process)
    Posted by David Bowen on January 30, 2023 at 8:46 pm
    I’ve spent a few hours scouring the internet for a hard and fast % that works with the Stretch and Pitch process to convert audio from 29.97 to 25 with very little success.
    So, I did some tinkering and found the number.
    Now before the galaxy brains chime in with “audio doesn’t have a frame rate, it’s just sample rate,” I know – I understand. It’s just a helpful mental shortcut to refer to the audio by its paired video’s frame rate.
    So, if anyone needs to convert 29.97 footage to 25 for whatever reason, the number you put in for Stretch and Pitch (for the audio) is:
    119.88
    The timing of the new audio will match the timing of the 25fps video and the pitch will remain the same… however, you will have to deal with speech that’s nearly 20% slower. If you want to avoid that, you’ll need your original recording to be in the frame rate you want to end up with.
    Cheers!
    Boston Cainfra replied 3 years, 5 months ago 2 Members · 1 Reply
  • Boston Cainfra
    March 17, 2023 at 6:10 pm
    Hello David
    I literally didn’t understand what you really want to address in your explanation but after some minutes then I understand what you wanted
    So To convert audio from 29.97 to 25 using Stretch and Pitch, enter 119.88. Nevertheless, this will cause speech to be over 20% slower, so if at all feasible, it’s better to have the original recording in the desired frame rate.
