Activity Forums VEGAS Pro The lowest bitrate
  • The lowest bitrate
    Posted by Carmen Emarda on March 12, 2012 at 2:47 pm
    hello Gentleman,
    I wonder how you guys set the lowest bitrate when encoding.
    For example a scene like many people singing together so
    it shows like a still-image in the monitor(No big movement).
    In this case the clever software like VEGAS think it has less movement or perhaps a still-image then set this scene (or this frame) for the lower bitrate.
    Now I set VEGAS the lowest bitrate as 192,000(default).
    Or do you suggest like 2,000,000 for the better quality for like this frame.
    I think if this frame is real still-image (like an inserted photo), then 192,000 seems enough but for scene from the movie….
    So what do you guys think this?
    Thank you in advance..
    John Rofrano replied 14 years, 6 months ago 2 Members · 1 Reply
  • John Rofrano
    March 13, 2012 at 12:43 am
    I don’t really play with the low and high defaults that the Sony programmers set (I only tweak the average) and I’ve never had any problems encoding files. My advice is if you see encoding problems, raise the bit rate. If you don’t, leave well enough alone. 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
