Activity Forums Apple Final Cut Pro The library appears to be damaged!
  • The library appears to be damaged!
    Posted by Emmanuel Guillaud on March 3, 2022 at 9:39 pm
    Hello,
    I have a very important library, full of videos, projects that are key to me. I opened it today (first time in months) and I’m greeted by a “The library appears to be damaged and won’t be backed up” message.
    I rushed to back ups…but there is nothing there (maybe because it has been few months since I’ve lasted opened that library).
    What should I do while I can still access the library? Should I copy all my projects in a new library and relink assets? But won’t the issue be copied as well?
    Library is on a reliable (I think?) external SSD (SanDisk Extreme Portable SSD).
    Thank you for your help.
    Patrick Donegan replied 4 years, 6 months ago 3 Members · 2 Replies
  • T. Payton
    March 3, 2022 at 9:49 pm
    Likely this was a temporary corruption that happened and is possibly resolved. I’ve seen this happen several times. However, to be safe, copying everything to a new library. It will likely resolve the corruption issue. If not, check out this article, starting with #4. https://blog.frame.io/2016/09/13/recognize-fix-common-problems-fcpx/
  • Patrick Donegan
    March 3, 2022 at 11:53 pm
    Sometimes files on SSDs dont last so long … they are not rated for long time storage unless constantly plugged in to do the refresh cycle.
    Maybe that happened.
    And maybe after the SSD being plugged in for a certain amount of time those files can be restored?
