Activity Forums Adobe After Effects The Kid Stays in the Picture
  • The Kid Stays in the Picture
    Posted by David Dibartolo on August 17, 2006 at 7:44 pm
    Does any one know how to accomplish the effect that was used in “The Kid Stays in the Picture”. I would really like to use that multi-layering of still images.
    thanks
    Reloaded replied 20 years ago 4 Members · 5 Replies
  • Death_or_glory
    August 17, 2006 at 8:52 pm
    I won’t go into the physics of parallax here, but this is the basic way to do this effect. The trick is to inroduce parallax where none exists.
    The best way to do this is to separate your foreground element (or elements) from the background, and paint in the background ‘behind’ the FG element. (If you have the opportunity to shoot the things you’ll be doing this with, simply shoot a clean plate of your BG)
    When you set up your comp, place the elements in z space and scale the BG and FG to visually match the original (use snapshot feat. if precision is involved)
    Camera trans reveals the gag. Most effective with more than 2 depth levels, ie. FG, Mid, and BG.
    Good luck!
  • Reloaded
    August 17, 2006 at 9:25 pm
    Do you have a link so we can see the effect?
  • Death_or_glory
    August 17, 2006 at 10:25 pm
    This is something I did awhile back as a quick test:
    https://chrisconn.net/parallax/baseball1.mov
    Its basically a quick way to bring stills to life. In this case, a Maya-generated baseball was added.
    For another good example, look at:
    https://media2.mk12.com/mk12_version_five.html
    under work for hire/2004: Cartoon Network: ASB
  • Chris Smith
    August 17, 2006 at 11:35 pm
    Search the archives for “kid stays picture”. This has been discussed many, many times in the last few years since the films been out. There is a wealth of knowledge waiting for you in the “Search Posts” option to the left <-- Chris Smith https://www.sugarfilmproduction.com
  • Reloaded
    August 18, 2006 at 12:09 pm
    Hi, there is a video tutorial about this kind of comp, maybe it’s worth taking a look. Here is the link https://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=2&page=https://www.creativecow.net/articles/kramer_andrew/3dcompositing/index.html
    I hope it helps.
