Activity Forums Adobe After Effects The judder mystery!!!
  • The judder mystery!!!
    Posted by Steve Morris on December 16, 2010 at 12:31 pm
    I’m trying to create a simple movie clip of a horizontal pan in After Effects. But it seems impossible without judder/jitter – whatever it’s called. I’ve read lots of posts on this but no-one seems to have an answer. Here’s what I’ve done:
    Imported a jpg of a stone bridge 1880 x 720
    Set composition to 25 frames/s and 1280 x 720
    Set anchor point to 0,0 – top left
    Set position to 0,0 and created key frame
    Move photo to -600,0 and set keyframe at 6 seconds
    That’s a movement in whole pixels!! 100 per/s or 4 per/frame
    Rendered to QT movie
    It looks terrible – smooth jitter, smooth jitter across the pan.
    I’ve tried 50 frames/sec (little better) and played with frame blending, motion blur, directional blur – no better
    Rendered to different compression even H.264 – no better
    It could be my computer not able to keep up – but it’s a reasonably new PC with pretty good spec. I’m trying to make a HD video for the web with this clip and some timelapses. If my computer can’t keep up with this movie then the average computer will also struggle – so most people will see the same problem. Is it too much to ask for a smooth pan or are average computers these days just not up to it. I don’t believe this is an optical illusion by the way as the pan is smooth in parts. Any help appreciated!!
    Steve Morris
    Zero Cool replied 14 years ago 4 Members · 8 Replies
  • 8 Replies
  • Michael Szalapski
    December 16, 2010 at 4:44 pm
    What’s the data rate of the files you’re rendering?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Steve Morris
    December 16, 2010 at 6:02 pm
    It depends – I’ve rendered it so many times with different options. For my latest it’s a 10Mb file with a data rate of 13mbits/s. I’ve tried putting the format slider for QT export in all positions from low to high quality – it makes no difference. Any help appreciated!!
    Steve Morris
  • Michael Szalapski
    December 16, 2010 at 7:02 pm
    I’m with Dave, does this judder show up in RAM previews or just in the render?
    – The Great Szalam
  • Steve Morris
    December 16, 2010 at 7:11 pm
    Thanks. I can see it in the RAM preview too!
    Steve Morris
  • Steve Morris
    December 16, 2010 at 8:02 pm
    Hi Dave
    If I put the viewing window to 50% and the resolution to half – it looks a lot better in RAM preview and plays in real time. Where do I go from here?
    Cheers
    Steve
    Steve Morris
  • Steve Morris
    December 17, 2010 at 10:38 am
    Hi Dave
    Thanks for trying anyway. The web is littered with people asking this same question about jitter, judder, jerky movement for horizontal pans on still images. I don’t understand why there isn’t a tutorial that says – to get smooth pans this is what you do!! Also the answers are always different eg try upping the frame rate or add motion blur, try frame blending, try directional blur.
    I’m beginning to think that the real answer lies in the average computer these days. It just can’t keep up with shuffling the whole picture (1280 x 720) 25 times a second. OK, if you’ve got 12GB of RAM, two drives and the latest graphics card – you maybe OK. But what’s the point of generating a video for the web that only looks good on a machine like that – Joe Average won’t see it smooth.
    Cheers
    Steve Morris
  • Graham Macfarlane
    December 18, 2010 at 1:06 pm
    I agree with Dave, I don’t think the computer is at fault with a 13mbits/s data rate.
    The apparent 25fps judder could be one or a combination of the following:
    – The eye is capable of seeing the individual frames when there is very fast motion present with an insufficient frame rate. Conversely if you had an animation of a very slow moving small object you might be able to get away with a very low frame rate before any judder is noticed.
    One can help alleviate judder with motion blur and of course the video data rate needs to be kept in check as Michael points out else the computer will struggle. However these solutions are never going to work as effectively as what Dave suggested – increasing the frame rate or reducing the speed of your animated motion.
    – The refresh rate of your monitor. Assuming your using a flat screen, which is normally 60Hz, a 30fps video fits very nicely into this rate. A 25fps video will work but it doesn’t divide as cleanly so the display of such video is not optimal. Maybe you can lower your screen refresh rate to 50fps (nice multiple of 25) or perhaps burn the 25fps video to DVD and trying it out on a PAL TV. You might find the playback is smoother however I appreciate that these display adjustments/changes may not be possible for the media’s end use.
    Graham Macfarlane
    3D animator and VFX specialist
    London UK
  • Zero Cool
    September 14, 2012 at 9:17 pm
    I’ve been having the same problem. The animation I created is a simple move of a picture from the left side of the screen to the right (simple position animation).
    When playing back AE exported videos rendered at 1920×1080 (1080P, 29.97fps Dropframe, 6-10mbps, H264, Best settings) the animation looks jittery in both windows media player and quick time. It’s much worse in quick time because it seems like a whole bunch of frames were dropped. Scrubbing the time bar doesn’t really help either. This is weird since h264 is supposed to be really good in Quicktime for 640×480 videos.
    The thing is if I play the video back on a HD plasma tv, it looks fine. The animation is perfectly clear and it doesn’t look like it does on the comp. I know this doesn’t help if you need to play your videos back on a computer for presentations. But if your goal is to play it back on a TV, then it should be fine.
    Good luck.
