Activity Forums VEGAS Pro the jitters
  • the jitters
    Posted by Brad Reuber on May 30, 2008 at 3:53 pm
    I’ve had a problem achieving smooth playback of dvd’s on plasma screens rendered through vegas and dvd architect. The problem areas are the dv captured footage. All pans and motion are very jittery. Almost seems like a interlace issue. My project consists of motion graphic composites (which play back seamlessly) and dv footage (which looks horrible). Should I be rendering the mpg lower frame or progressive? I realize that the dv footage is captured lower frame first but should it make a difference of playback on the dvd when rendered to progressive? Thanks in advance.
    John Rofrano replied 18 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    May 31, 2008 at 10:20 pm
    Yea that does sound like interlacing issues where the field order is reversed. You might want to render the project as progressive just to eliminate it all together. This way it will be progressive on a progressive display and any DVD player will interlace it if it is connected to an interlaced TV.
    ~jr
    https://www.johnrofrano.com/
