The “Jaggies” ???
Posted by Ken Bennett on January 15, 2014 at 11:14 pmI get the”jaggies” on straight edges on moving camera shots from time to time. My default is set to UPPER FIELD. Is there an rhyme or reason why this would change and make you select LOWER FIELD? Or is it always “trial or error”?
I also always have BLEND FIELDS on.
Feedback?
THX
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures!Stephen Crye replied 12 years, 8 months ago 4 Members · 5 Replies -
Stephen Mann
January 15, 2014 at 11:37 pmWhat’s the format of your source? What camera? You may be seeing CMOS rolling shutter artifacts.
Rolling Shutter (Jell-o Effect)
Rolling shutter is endemic on CMOS chips because of the progressive scanning nature of the electronics. The image is made from scanning top to bottom, much like you read a book. Rolling shutter artifacts occur when something changes in the frame in the time it takes the chip to be fully scanned from top to bottom,Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Steve Rhoden
January 16, 2014 at 1:24 amBecause you need to change it from Upper Field first to
None (Progressive Scan).Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
Ken Bennett
January 16, 2014 at 3:23 amFormat HDV 1440×1080-60i, Sony Z7s.
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures! -
Ken Bennett
January 16, 2014 at 3:29 amThis usually happens when I render my MPGs out in Vegas. When I let DVDA do the rendering, I don’t get them.
If I render MPGs in Vegas, do I just set the render to progressive or do I need to change that also in Properties?
Ken Bennett
Video Adventures
Stephen Crye
January 16, 2014 at 6:33 amKen, I do a lot of that, no problems.
My interlaced cam is a Sony HDR-CX550V . I typically shoot in 1920×1080 60i. I make DVDs and Blu-Rays from the footage. No jaggies, just a nice motion blur. The defaults seem to work pretty good.
Project properties screen shot:
MainConcept MPEG-2 Render template screen shot:
Hope this helps, you can always play with Interpolate vs Blend and see what you like best.
Steve
Win7 Pro X64 on Dell T7500, MultiTB SATA, 8GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
