Activity › Forums › Compression Techniques › The Jagged Vector Blues
Posted by Rich Binder on July 13, 2009 at 9:56 pmHey all, I’ve got super jagged edges in the high-color contrast areas of my otherwise clean compressed movies. Here is a link to what I’m referring to, it’s most noticeable in the roof of the birdhouse and the backpack.
https://www.tmdcreative.com/ccfcu/
Any thoughts on how to remedy this or is it just the facts of life?
Rich B.
Daniel Low replied 17 years, 2 months ago 2 Members · 5 Replies -
Daniel Low
July 14, 2009 at 2:48 pmShould be pretty easy to fix but you need to explain your workflow. How did you create those graphics?
How did you get them in to your composition?
What applications do you use?
What setting did you use for the composition mixing graphics and live video?__________________________________________________________________
Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004 -
Rich Binder
July 14, 2009 at 3:47 pmGraphics were created in Illustrator, video footage is HDV, all thrown into After Effects for animating. The AE composition was just the basic HDV settings and the final movie was exported to FCP using the Animation settings.
Everything looks perfect at every step of the process except at export.
Daniel Low
July 14, 2009 at 6:52 pmLooks like there’s an issue with rasterisation on those certain vectors in AE.
Rich Binder
July 14, 2009 at 7:07 pmEven though they look fine in FCP? Wouldn’t the problem lie in my Compressor settings from FCP? Just wondering.
Daniel Low
July 14, 2009 at 7:40 pmIt’s possible it could be compressor if you have mixed interlace and progressive content and didn’t apply a deinterlace control.
By the looks of it both animation and video are progressive?
I’d really need to know detailed information on your AE comp settings, your FCP sequence settings and your compressor settings before I could make a final call.
