Activity Forums Adobe After Effects The Great “Video Preview” Myth
  • The Great “Video Preview” Myth
    Posted by Bendex on December 30, 2005 at 4:42 am
    After 5 years of using After Effects in a professional video production studio I have come to the conclusion that there is no such thing as “Video Preview” to an external monitor from After Effects. I’m not entirely sure why Adobe invented this lie or why it has gone unexposed for so long, but if someone of my stature can try for so many hours and not figure it out, then it just isn’t real.
    Oh go ahead… try to prove me wrong. My configuration is as follows.
    Software: After Effects 6.5 on Win XP.
    Connection to monitor: Firewire via Sony DSR-11 deck (video preview works in Avid)
    Video Card: Nvidia Quadro FX 3400
    Yes I’ve tried Preferences>video preview>IEEE… No the Avid After Effects EMP plugin doesn’t work either. Yes I’ve tried on multiple computers (though with the same deck).
    I would do anything and pay ANYTHING to have this feature work.
    Bendex.
    Accountneedsrealnameupdate replied 20 years, 7 months ago 14 Members · 24 Replies
  • 24 Replies
  • Steve Roberts
    December 30, 2005 at 5:22 am
    Hmm … a challenge.
    I’ve just tried the FW preview for the first time on this Dell XPS Gen2 laptop running XP, by hooking it up to a little Optura Pi. I hooked up the FW cables, launched AE 6.5, set up a comp, then set the display prefs to IEEE 1394 NTSC with the first three boxes checked (previews, mirror, interactions). Worked like a charm during RAM previews and scrubbing. At least on the camcorder’s flip-out monitor.
    Maybe I’m mything something (sorry) ….
    1. Have you tried it on computers that have no Avid installed?
    2. Have you tried it without the Avid running?
    I smell conflict with the Avid. As you know, sometimes two apps don’t share the preview very well. Could this be it?
    Steve
    (by the way, you probably know this Bendex, but for anybody else reading, IEEE is pronounced eye-triple-ee. It’s an Electrical Engineering Association. Or Institute.)
  • Chris Smith
    December 30, 2005 at 6:26 am
    [Bendex] “I would do anything and pay ANYTHING to have this feature work.”
    About $800 bucks for a Decklink Extreme card to give you uncompressed component output. Will look better than the compressed DV signal thru FW any day.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Mylenium
    December 30, 2005 at 10:44 am
    I think your problem is somehow related to the Sony hardware. Thought they have dropped their insistance on using their “iLink” flavour of firewire, there are still problems with their hardware. I believe they don’t send certain control bits which would make the hardware plug&play compliant. Perhaps that is the problem. On my end I have had little problems. Though I don’t use this feature most of the time, it works for me even on the cheapest of hardware combinations (budget computer with consumer DV device). The only drawback is that it sometimes will only work as NTSC where it should be PAL.
    Mylenium
    [Pour Myl
  • Bendex
    December 30, 2005 at 11:20 am
    I must admit that I haven’t tried it with no Avid installed, but I have tried it with no Avid actually running.
    When I select the IEEE option in “Video Preview” and press OK it tells me:
    “After Effects warning: device Type doesn’t match Output Mode selected. (81 :: 1)”
    It’s probably the deck. What alternatives do you suggest? (without having to buy a new expensive deck)
    Bendex.
  • Mike Smith
    December 30, 2005 at 11:32 am
    It sounds very unlucky for you.
    You must be the victim of a system conflict: I’m looking at uncompressed, realtime full-SD preview from AE via a Decklink card right now, and can switch to firewire preview via a DVCAM deck via the preview settings in a matter of moments … so it really is worth persevering to find out where the conflict lies in your system. It it’w with Avid software, that should be well documented.
    It saves a lot of time to preview rather than have to export / play out to video / come back and change things.
    Do you use Photoshop – does the preview work on that?
  • Clint Fleckenstein
    December 30, 2005 at 1:58 pm
    Works fine for me on my Canopus machine here at work and on my dpsVelocity at home. But I use the Velocity plug-ins for previewing out of that one anyway.
    Clint
  • Sean Cusson
    December 30, 2005 at 4:54 pm
    I use a Matrox RTX.100 card to preview with, but I can also preview straight from Firewire using a Sony DSR20 DV deck.
    Sean Cusson
    Q media design
    sean@qmediadesign.ca
  • Phil Biggs
    December 30, 2005 at 5:45 pm
    On my PC, I’ve never even had the option of firewire output in my AE preferences dialogue. The only option available is “Desktop Only” – not even a greyed-out firewire option. It works fine on my Mac using the same DV deck and cables (and same AE version) – but I have to use echofire for PC PAL previews. Answer me that and stay fashionable!
  • Steve Roberts
    December 30, 2005 at 5:59 pm
    Firewire preview for Windows was added to recent versions of AE, starting with 6.5, I think. Echo Fire was necessary before that.
    Steve
  • Jonathan Miller
    December 30, 2005 at 6:23 pm
    Just so we can eliminate the obvious…
    Your DSR-11’s input is switched to “DV” and not “S-Video” or “Video”, right? It’s right on the front of the deck.
    Sometimes these simple checks can save the day.
    Jon
Page 1 of 3
