Activity Forums Adobe After Effects The gradation it is a question against an effect.
  • The gradation it is a question against an effect.
    Posted by Spiritegun on January 22, 2007 at 3:38 am
    When putting in a gradation effect in the object, it used the Ramp and it put in an effect. (1)
    It used the Ramp and when puts in an effect the object moves, the change of color occurred. (2)
    The object moves and the plug-in which is not change of color or it is what with the method which is simple? (3)
    Steve Roberts replied 19 years, 8 months ago 3 Members · 3 Replies
  • Mylenium
    January 22, 2007 at 6:21 am
    I don’t really get what you are trying to say and if you attached a picture, it’s not showing up. Your Ramp should not move intermittently when you move the object, as it is tied to the layer. Unless of course you are using some kind of matte mode or adjustment layer. The colors should not change, either. You’d only see a slight change in saturation if you use motion blur, but that’s normal. Like I said, I don’t really have a clue.
    Mylenium
    [Pour Myl
  • Spiritegun
    January 22, 2007 at 11:29 am
    Reply Thank you.
    It tried the maximum effort oneself but did the result it will can use hold and to come it inquired.
  • Steve Roberts
    January 22, 2007 at 4:16 pm
    Please … could you tell us which language you speak, and post your e-mail address, so (maybe) someone who speaks your language can contact you directly.
    (It might happen, or it might not.)
    (If you do not want to post your address, we understand.)
    Thank you.
