Activity Forums VEGAS Pro The Forum “Code” Tag Is Currently Broken
  • The Forum “Code” Tag Is Currently Broken
    Posted by Matt Carlson on June 25, 2014 at 4:39 am
    I posted a script using the code tag earlier today. Since I have not had any problems in the past with the code tag I did not do a line for line check of the script in the post. Later when the script did not work I noticed that the forum is filtering out < > even inside a script block. This, of course, is instantly fatal to any C# code needing things like Lists. Until they get it fixed I suggest just posting scripts by linking to an uploaded forum file.
    John Rofrano replied 12 years, 2 months ago 3 Members · 2 Replies
