Activity Forums Adobe Premiere Pro The dreaded red pixels.
  • The dreaded red pixels.
    Posted by Ali Paterson on August 24, 2009 at 1:15 pm
    Hi there, Im trying to render a two hour long film, and have been stuck by the dreaded red pixels that keep appearing between cuts. I’ve resulted to rendering the entire project, cutting out the pixelated bit, re-rendering the project to remove the majority of the “bad Bits”, but have been left with about 7 sections, (about 2 second long each, which just refuse to lose these red pixels. Is it a problem with première, or the files, because they render perfectly one time, and then terribly the next
    I shot the footage on HDV, and have been exporting as .m2v
    regards
    Ali
    http://www.inopeanfilms.com
    Ali Paterson replied 17 years ago 3 Members · 5 Replies
  • David Dobson
    August 24, 2009 at 8:21 pm
    Do you need to export m2v (hdv) or could you use something else?
    H.264 is much better codec and a lot more stable.
    Have you tried deleting all the preview files?
  • Vince Becquiot
    August 24, 2009 at 8:34 pm
    And what plugins are you using?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Ali Paterson
    August 24, 2009 at 8:44 pm
    Just the standard default, i.e. no new ones installed
    im trying the other codec now
    recommend any pluggins?
    regards
    Ali
  • Vince Becquiot
    August 25, 2009 at 4:52 am
    That would have been caused by a third party plugin, and it most likely would show up in the timeline preview as well.
    Maybe posting a screen capture would help us, but it doesn’t sound like anything I’ve seen myself.
    Vince Becquiot
    Kaptis Studios
  • Ali Paterson
    August 28, 2009 at 1:01 am
    Brilliant – got them Exported using the H.264 code as .m4v files.
    been very helpful
    any general tips as to how to get these to a blu ray or dvd?
    thanks again
    Ali
