Activity › Forums › Apple Final Cut Pro › The dreaded A/V Output “none found” is back
  • The dreaded A/V Output “none found” is back
    Posted by Georg P. mueller on April 20, 2015 at 9:09 am
    I am using an ultrastudio express to connect to my SDI HD monitor. Today it stopped working with X. I remember having exactly the same issue on another system running the mini monitor a while back. The only thing that made it work at that time was reverting to an ancient blackmagic driver.
    I had this problem twice – so surely I can’t be the only one..? But I couldn’t find any working solution online. Uninstalled, re-installed, tried all different settings, Pal and NTSC, etc.
    So I was wondering whether any of you guys ever ran into this problem…
    The strange thing is that the ultrastudio works just fine with good old FCP7 – only X fails to see it…
    Georg P. mueller replied 11 years, 5 months ago 3 Members · 4 Replies
  • Tom Brooks
    April 20, 2015 at 11:15 am
    When FCX is not seeing the BMD device, is the OS able to control it, or is it disabled at the OS level as well?
  • Michael W. towe
    April 21, 2015 at 2:57 am
    In the past with BMD devices I have needed to reinstall the Desktop Studio software after installing X updates. Give that a whirl.
    Michael W. Towe
    President M2 Digital Post
    http://www.m2digitalpost.com
  • Georg P. mueller
    April 21, 2015 at 6:40 am
    Hi Guys,
    Thanks for chiming in. I still haven’t resolved the issue. I have tried several BMD thunderbolt devices – same result. It shows up under system prefs and also works fine with FCP7.
    But X fails to see it.
    I have reinstalled Yosemite from the recovery disk – no change. I have tried to revert back to BMD desktop video version 9 (the one that works) but it wouldn’t allow me to install it on the current OS (10.10.3). I have uninstalled/re-installed and tested the previous versions 10.3.5 and 10.3.7 of BMD desktop with no success.
  • Georg P. mueller
    April 21, 2015 at 6:54 am
    I thought I get tricky now and force-install driver 9.9.2 using the Pacifist installer, by-passing that error message about my OS. It asked me to overwrite all kinds of existing files which I allowed. The installation didn’t work and the BMD device not recognized in system prefs.
    So I over-installed the current driver 10.4 again (for the 5th time). Started FCPX and (drumroll…) – it works now!
    So I guess when you uninstall the blackmagic driver it does not remove all files and when you re-install it does not overwrite everything that is left. Pacifist did it though and now I am BACK in business!
