Activity › Forums › Maxon Cinema 4D › The “degree counter” for the camera become negative after 270 degrees
  • The “degree counter” for the camera become negative after 270 degrees
    Posted by Bengt Bengtsson on March 23, 2015 at 2:29 pm
    Hello I have a target camera aligned to a spline (a helix). I want the camera to orbit around a box and it does, smooth and fine. The problem is that I want to copy the values for the camera rotation for every frame and make g-code of it. It works fine until the value of the camera rotation pass 270 degrees then it starts on minus 90 instead of continue up to 360… is there a way to solve this problem?
    best regards: Bengt.
    Brian Jones replied 11 years, 6 months ago 2 Members · 1 Reply
  • Brian Jones
    March 24, 2015 at 6:33 pm
    search for Gimbal Lock in the forum. Adam has posted some good advice
