Activity Forums Blackmagic Design “The deck may be unable to perform this edit operation since the edit duration is only one frame”..message
  • “The deck may be unable to perform this edit operation since the edit duration is only one frame”..message
    Posted by Anders Haavie on April 21, 2005 at 9:03 am
    Sometimes I get this error message when I do insert edit on our digi. Using latest fcp with a 2×2 G5 and xsan.
    Anyone else got this ? Is there an easy way around this bug ?
    Anders
    Anders Haavie replied 21 years, 5 months ago 3 Members · 3 Replies
  • John Christie
    April 21, 2005 at 10:00 pm
    Anders
    I’ve seen this happen on 2 of my systems running Cinewave. My solution has been to set a longer duration, or copy the time line to a new one and try it from there.
    Cheers
    John Christie
    Keyframes Editing
  • Phil
    April 22, 2005 at 2:29 pm
    This happen when you have to pick up mult inserts. The only way around it is to change duration (often drasticlly in both directions) or as we do, copy into a new seq from that timecode forward. Ya big bug, just like the 24p to 30 outputs were you have to calculate the frame differences otherwise it will stop recording early. Pain for inserts:(
    Phil
  • Anders Haavie
    April 23, 2005 at 11:32 am
    really annoying. It will evetually work after making new in and out points, but it would be great to know that the decklink guys are working on the problem.. or maybe its not a decklink problem at all ?? Maybe it’s fcp acting up ?
    Anders
