Activity Forums Apple Final Cut Pro Legacy The connection between rendering and graphic card.
  • The connection between rendering and graphic card.
    Posted by Arnljot Bringedal on January 9, 2007 at 4:06 pm
    Hey!
    In the process of buying a new mac pro.
    The standard graphic card – is it good enough for normal work?
    Will I see shorter render times if I upgrade it? Or is it just CPU and RAM that matters when rendering? ( I Only render effects forme M:B editors )
    Thanks for any replies!
    *** Norwegian videojournalist & Editor***
    Michael Bloodgood replied 19 years, 8 months ago 8 Members · 12 Replies
  • 12 Replies
  • Joe Paolo
    January 9, 2007 at 6:01 pm
    A better video card will help with program responsiveness in Motion especially and maybe somewhat in FCP. Rendering is all CPU AFAIK.
    joe
  • Arnljot Bringedal
    January 9, 2007 at 6:34 pm
    Thanks Joe!
    I kinda figured that the guys at Apple store wanted to sell me more than I needed:-)
  • David Roth weiss
    January 9, 2007 at 8:46 pm
    Keep in mind, things will change soon (hopefully) when FCP becomes 64-bit and utilizes the full potential of GPU-accelerated plug-ins based on the FxPlug architecture.
    DRW
  • Peter Wiggins
    January 9, 2007 at 9:09 pm
    Things have already changed as pointed out, FxPlug plugins use the graphics card to render.
    So for those, the beefier the card, the faster the render.
    Peter
  • David Roth weiss
    January 9, 2007 at 9:35 pm
    And Peter, if I’m right, this will become very much more important when fully exploited in the 64-bit version due from Apple in the ___ quarter, of 200_.
    DRW
  • Joe Paolo
    January 9, 2007 at 10:14 pm
    SO.. the graphic processor is used when rendering FxPlug plugins?
    joe
    joe
  • 13 Create COW Profile Image
    13
    January 10, 2007 at 2:55 am
    “The standard graphic card – is it good enough for normal work?”
    That depend what you YOU concider “normal work”
  • Rafael Amador
    January 10, 2007 at 11:54 am
    You say that your using MagicBullet Editor. In that case I’ll rather install in my Mac a Nvidia instead of a ATI. The peopleo of MB say that with NVidia MB effects render faster than with the ATI.
    Salud,
    Rafael
  • Arnljot Bringedal
    January 10, 2007 at 4:09 pm
    What I consider normal work?
    I think I stated that in my original post.
    Normal cutting – with minimal rendering.
    The “only” rendering I do today , is when I colorgrade with MB editors.
    Becker
  • Arnljot Bringedal
    January 10, 2007 at 4:21 pm
    Really?
    Wow – thanks – i did not know that!
    As glad as I am for being given an answer – it leaves me also somewhat more puzzled….
    Some say rendering ( with current FCP version ) is CPU only – others say the Graphic card matters.
    So what is it? CPU? Graphic card? Both? Anyone care to settle this once and for all?
    Regards
    BEcker
