Activity › Forums › Adobe Photoshop › the command delete is not available?
  • the command delete is not available?
    Posted by Bob Flood on July 25, 2007 at 4:30 pm
    Hi
    I am a video editor who is using the best CG in FCP, namely Photoshop
    I am making titles with shadows and glows and all that in PS v8, and when i want to save them out here is what i do
    i select the layer that has the type and effects
    I create layers of the effects
    I merge layers
    I delete my alpha channel
    I load seelction on my text layer
    i save selection on my text layer
    and then i save it out as a 32 bit tga or pict, depending on my mood 🙂
    I have written an action to do all the steps above except the first and last
    BUT every time i run the action i get an error message: “the command ‘delete’ is not currently available”
    i can understand that message when i have no alpha, but i get when i have an alpha and want to make a new one
    how can i fix this? and or is there a way around this issue?
    thanx
    bee eph
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Bob Flood replied 19 years, 1 month ago 2 Members · 2 Replies
  • Richard Harrington
    August 3, 2007 at 12:49 am
    There is an action built-n to Photoshop…
    Click on the Actions palette and load the Video Actions (that I wrote).
    If you want to read the steps…
    https://www.photoshopforvideo.com/conferences/psworld/AutoForVideoPros.pdf
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Bob Flood
    August 6, 2007 at 4:07 pm
    thanx richard
    i do not have the actions you mentioned in my version of Photoshop(CS aka V8) however I made one using the steps described in your PDF
    I did have to add a “pre action” for deleteing the existing alpha channel, or else I get multiple alpha channels everytime i run the action. (my workflow is such that i may be making mutiple graphics in one PSD, then saving them as individual Pict files)
    I have saved the doc you linked me, and will refer to it often!
    bee eph
    Bob Flood
