Activity Forums DaVinci Resolve “The clip XXX cannot be linked to.. because reels doesen´t match”…. what?
  • “The clip XXX cannot be linked to.. because reels doesen´t match”…. what?
    Posted by Kent Kumpula on July 31, 2011 at 7:26 am
    OK, so I am trying to get my Resolve to work. but it isn´t going too well.
    First, I tried to export a Premiere Project to Resolve with EDL, XML or whatever… nothing worked. Then I read about compability issues with Premiere rountrip, so I thought I would try to get Resolve running with a Final Cut roundtrip.
    So I have made quite a few testprojects in Final Cut PRo now, trying if ÅÄÖ in the filenames would be the problem, and other stuff, but it just isn´t working at all for me.
    When I export a XML from Final Cut, load it in the conform page I get the following message (after telling Resolve where the original file can be found):
    4 of 4 clip(s) have been found.
    4 source clip(s) have been imported into the media pool.
    Use XXX as the new session name.
    The clip “XXX” can’t be linked to the media file “XXX” because the reels doesn’t match.
    The project contains one file, divided to four cuts/edits/clips. What am I doing wrong? I read all nice posts about how stable Resolve is… but I haven´t managed to get one single, short, testproject from neither Premiere nor Final Cut properly imported to Resolve. 🙁
    Jonathan Seaborn replied 14 years, 10 months ago 5 Members · 6 Replies
  • Ola Haldor voll
    July 31, 2011 at 10:12 am
    What settings do you have in the Config page prior to importing media files and loading the EDL?
  • Kent Kumpula
    July 31, 2011 at 9:17 pm
    I´m not in front of my macs now (they are at the office), but the same resolution and framerate as the original files. Then there is a bunch of other settings too, I can check those tomorrow. Any specific setting you suspect to be incorrect?
  • Kent Kumpula
    August 1, 2011 at 10:21 am
    Here is a screengrab with all the settings.
  • Rohit Gupta
    August 1, 2011 at 10:52 am
    It seems the the reel/tape numbers from the XML and the method you are using to extract them from the media don’t match.
    Try switch off the reel number completely by switching off the “Assist using reel numbers from the:”
  • Sascha Haber
    August 1, 2011 at 2:00 pm
    If you use the pattern, click on test to see if it actually works.
    You can alter the variables in there to accommodate for your naming topology.
    If you can provide us the path and name, we might help with the variables.
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Jonathan Seaborn
    October 21, 2011 at 1:49 am
    Get the same message
    i export an oaf from abc 5.5
    format 1080P/23.976
    i setup my resolve 8.1 the same way
    i tried with the assist using real number… and without
    with the assist the message is
    The clip “” can’t be linked to the media file “MVI_7758.mov.V14EA0C783.mxf” because the reels doesn’t match.
    without the assist:
    The clip “” can’t be linked to the media file “MVI_7758.mov.V14EA0C783.mxf” because the timecode extents doesn’t match.
    the conform page load my aaf but all the clip are missing and mark with an red X
    amc 5.5
    osx10.7
    Resolve 8.1
    DNXhd plugin
    if someone know how to do it?
