Activity Forums Apple Final Cut Pro Legacy the case of the sequence split personality…
  • the case of the sequence split personality…
    Posted by Bob Flood on January 4, 2006 at 6:28 pm
    Hi
    i was working on a nested sequence yesterday doing a series of split screens, and cut the nest into my main sequence
    today i wanted to revisit said nested sequence to replace some shots, and when i clck it open in the browser it was missing about half the stuff i did (from a point where i made a copy with a new name.)
    ok so i have been having this issue and i know its probably cuz i am not up to the speed i should be, so i figure its just something more i gotta redo later
    HOWEVER
    when i double click on the nest in my main sequence BAM! all the work i did yesterday showed up! in a sequence with the same name! that i did not make redundant…
    so, how can i get this nest, the good one, into my browser to rename it AND OR what the f is the deal? how can there be 2 versions of the same sequence? one in the browser thats different from the one in the timeline?
    BTW the manual has nothing about this kind of wierdness, and based on what the manual sez i did everything right
    g5 fcp5.0.4
    bee eph
    Gary Hughes replied 20 years, 8 months ago 2 Members · 3 Replies
  • Gary Hughes
    January 4, 2006 at 7:11 pm
    [Bob Flood] “so, how can i get this nest, the good one, into my browser to rename it”
    I’m not sure, but I bet you could drag it straight from the timeline to the browser. If not, drag it from the timeline to the viewer, then drag from the viewer to the browser. I haven’t tried either, but I bet it’ll work. Although, after you drag it to the browser and rename it, I’m not sure if that will create a “copy” or an “instance” of the original. (Maybe someone else will comment.) So, after dragging it to the browser, if you find that it is a copy and not an instance of the original, simply drag it from the browser to the viewer or timeline and replace the original nest in the timeline. I know that will create an instance and you’ll be good to go.
    [Bob Flood] “How can there be 2 versions of the same sequence? one in the browser thats different from the one in the timeline?”
    Like most everything in FCP, there are several ways of creating and/or dealing with nested sequences. Some of the ways actually create or deal with a “copy” rather than an “instance” of the original. Rather than getting into all the details, I’ll just tell you what works very well for me.
    When I want to nest a sequence into another sequence, I always drag the sequence from the browser to either the viewer or directly to the timeline. By doing so, you can treat it as if it were just a clip and you will also always be working on the right sequence. Whether opening the original sequence from the browser or by double clicking on it in the other sequence, you’ll always be editing on the original and it will always update at both places.
    If, on the other hand, you desire to use a copy of a sequence as a nest inside another, I would duplicate it first, then rename the duplicate, then drag the duplicate to the viewer or timeline.
    If on the other hand, you desire to use only part of the sequence that you’re already working on, and wish to just nest a complex part, I would copy all tracks for the duration of the complex part, then create a new sequence and paste that into it, (be sure to drag out some heads and tails if you wish to have a transition at the start or end), then save that and drag it from the browser to the viewer or timeline.
    You can see my pattern. I always drag from the browser. There are other perfectly good ways, but that’s the one that works for me.
    Hope this helps,
    Gary
  • Bob Flood
    January 4, 2006 at 9:31 pm
    thanx gary
    this sounds like a plan, it sounds like i should be sure that everything comes form the browser.
    how about doing the nest command? build an effect in your main timeline, mark in and out, then press the nest command?
    or is that not good?
    bee eph
  • Gary Hughes
    January 4, 2006 at 9:39 pm
    I’m not going to say it isn’t good, but it isnt’ the way I work. That way has a purpose, but it isn’t for me. There are many right ways and since I don’t use that method, I don’t want to comment on it. Someone else take a stab at that one.
    My thought is, if I always make sure that the nest is built by dragging from the browser, then I’ll never have to keep up with “what does this and what does that”. I have one way, and if there are other variable, I always try to make sure that the end result is by my one way, then I’ll always know it’ll work the way I want it too.
    Other editors will purposefully use two ways so they can one time have a nested instance, and another time have a nested copy. I simply do that by duplication as I said before.
    Gary
