Activity Forums Apple Final Cut Pro Legacy The Best Thing about FCS3!!!
  • The Best Thing about FCS3!!!
    Posted by Bob Flood on August 21, 2009 at 4:47 pm
    I dont know if this was implemented in 6? but i know its in 7…
    wait for it……
    YOU CAN DELETE, INSERT, CUT, PASTE OVER A TRANSITION!!!!
    NO MORE ERROR MESSAGE ABOUT A TRANSITION CONFLICT!!!!
    YAAAAY
    (as you can see it doesnt take much to make me happy!)
    Bob Flood replied 17 years ago 5 Members · 10 Replies
  • 10 Replies
  • Jason Kalinoski
    August 21, 2009 at 5:28 pm
    Woo-hoo! You’re right!
    I just installed the update yesterday and there’s a lot of nice little things…well, little things that were really stupid in the first place but are finally fixed.
    Speed changes that don’t ripple the timeline! Add multiple transitions at once!
    I can honestly say, since installing the upgrade I’ve wanted to punch the screen a good 10% less…LOL.
  • Shane Ross
    August 21, 2009 at 7:44 pm
    [Bob Flood] “YOU CAN DELETE, INSERT, CUT, PASTE OVER A TRANSITION!!!!
    NO MORE ERROR MESSAGE ABOUT A TRANSITION CONFLICT!!!! “
    Well, i hate to beg to differ, but…not working for me. I have a clip that starts at a cut, then has a dissolve at the tail, standard 30 frame dissolve. I mark IN a the head of that, then OUT where the clip ends…halfway through the dissolve…and then try to OVERWRITE the new footage in, and I get the “this edit cannot be done because a transition would be cut…bah bah bah” error. Same error.
    Same happens when I try to paste a clip over the same transition. If it would overwrite it COMPLETELY…it works. But if it would only affect part of the transition…I still get the same error.
    And I can’t see any preference that allows me to change that.
    What exactly are you doing?
    Shane
  • Bob Flood
    August 21, 2009 at 8:24 pm
    hi
    FCP7 aka FCS3
    select a clip, press x (mark in and out) hit f10 and BAM! shot goes right in, taking out the dissolve.
    My transitions are set for Start at Cut as well. I have not tried it with different alignment.
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Shane Ross
    August 21, 2009 at 9:17 pm
    Ok, I can only get this to work if the dissolve ENDS on the previous clip…up to the IN point of the new clip. I can add footage that way…but then the dissolve that remains still contains imagery from the clip I replaced….so that seems pointless. But on a clip that is part of a dissolve and the dissolve starts on the in point of the NEXT clip…I get the same error.
    I might have to do a screen capture. This just isn’t working for me, other than that ONE way, out of three possible ways to have a dissolve, and that way that works, well, the dissolve needs to be removed anyway.
    Shane
  • Bob Flood
    August 21, 2009 at 11:36 pm
    Shane
    It did seem to work for me, but now its the same error message as before…I am confused and apologize for getting everyones hopes up 🙁
    lemme see if i can find out how i did it again, and i’ll let you all know
    Bob Flood
  • Elijah Lynn
    August 22, 2009 at 12:05 am
    [Jason Kalinoski]
    Re: The Best Thing about FCS3!!!
    by Jason Kalinoski on Aug 21, 2009 at 1:28:33 pm
    I can honestly say, since installing the upgrade I’ve wanted to punch the screen a good 10% less…LOL.”
    All you have to do to succeed in software is to consistently suck less with every release.
  • https://www.codesimplicity.com/archives/137
  • Mark Palmos
    August 25, 2009 at 10:46 am
    [Bob Flood] “It did seem to work for me, but now its the same error message as before…I am confused and apologize for getting everyones hopes up :(“
    LOL
    howzit bobarama!
  • Bob Flood
    August 25, 2009 at 2:36 pm
    MAAARKUUUUS!!!
    hey man, i coulda sworn i cut over a dissolve and didnt get the error!
    but maybe it was my bad short term memory…wait what was i talking about?
    (hahahaha)
    Bob Flood
  • Mark Palmos
    August 28, 2009 at 3:00 pm
    hey there bob
    ja, im not sure of all the rules and reasons, but it seems that if you have two clips with a transition in between like this:
    _______x_________
    and if you then mark an i and o before and after the transition like this
    ____i___x___o______
    then you can overwrite the transition.
    if you are parked on the outgoing clip and press X to select the clip, it selects the whole clip and the whole transition and will replace to the end of the transition, BUT if you mark the in or out point at the midpoint of a transition, it isnt smart enough to know you want to keep the transition.
    but hey, it is nice to know that you can add transitions to multiple edit points, (erm, like discreet edit could do over 10 years ago!)
    later gater
    mark
  • Bob Flood
    August 28, 2009 at 7:55 pm
    Markus:
    _______x_________
    ____i___x___o______
    YES! Very well explained!
    And i think that behavior is new to either 6 or 7, cuz it seems you Always got the conflict no matter where you marked around a transition using 5 ie FCS1
    I am LOL out loud!
    Bob Flood
  • We use anonymous cookies to give you the best experience we can.
