Activity › Forums › Adobe Premiere Pro › The best solution to convert HD to SD in Pr?
  • The best solution to convert HD to SD in Pr?
    Posted by Peter Kolarski on December 4, 2009 at 4:39 pm
    Hi again guys,
    As You probably know Pr isn’t great in doing clear/sharp SD from HD footage on default setting. So my question is – what I have to do to make it clear and sharp as it would be native SD from the start.
    Should i use some precise setting when doing output or use some special codecs/plugins?? or maybe Use different program and then use Pr as a montage soft.
    Any suggestions?
    Brian Louis replied 16 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Hector Melendez
    December 4, 2009 at 5:51 pm
    I had hear about Sorenson Squeeze but I don’t know how it works.
    https://www.sorensonmedia.com/
  • Peter Kolarski
    December 4, 2009 at 8:16 pm
    Well so it’s hard to say anything when You adv. something which You don’t know how it works… :/
    And it’s not cheap…….
    What I was thinking about was more like special settings in Pr or plugin based thing not another 800$ soft just for occasional transcoding.
  • Brian Louis
    December 4, 2009 at 10:06 pm
    There are a few ways, downconvert to DV in your camcorder if you have the capability, edit in DV, encode to dvd.
    another way is to use Virtualdub with the Lanczos3 filter, you can do a net search for “virtualdub downconvert” for more info
  • Peter Kolarski
    December 6, 2009 at 10:14 pm
    The material im usualy working now is
    Type: MPEG Movie
    File Size: 3,6 GB
    Image Size: 1440 x 1080
    Pixel Depth: 32
    Frame Rate: 25,00
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:19:52:12
    Average Data Rate: 3,1 MB / second
    Pixel Aspect Ratio: 1,3333
    Sometimes i need to export it to DV format (PAL DV AVI or DVD). I found once a tutorial (can’t now) what setting put on Pr (likes how many passes etc) to make good looking DVD from HDV material.
    So downcoverting in virutal dub will do just fine? And it’s weird that Pr has problems (as i read not only me) with such operations.
  • Brian Louis
    December 7, 2009 at 9:21 am
    There aren’t very many NLEs or encoders that do a top job in downconverting, I think its along the lines that not very many manufs in the past expected for DVDs to still be around so didn’t plan accordly and foot dragged, some will do a reasonable job but still get artifacts with motions and off axis lines, virtualdub does a good job minimizing these
  • Eric Jurgenson
    December 9, 2009 at 3:54 pm
    I don’t hear anyone mentioning After Effects, which is one of the best converters out there.
  • Brian Louis
    December 10, 2009 at 8:41 am
    I have AFX as part of Production Studio, but I didn’t mention it as the early part of this thread mentioned being able to do it on the cheap, which the virtualdub(free) method is
