Activity › Forums › VEGAS Pro › The Best HQ Rendering Settings Sony Vegas 9
  • The Best HQ Rendering Settings Sony Vegas 9
    Posted by Shawnie Jones on May 17, 2011 at 11:04 pm
    Im trying to figure out the best rendering settings for this music video. I thought I had a good one. But when I upload it to youtube its looks very bright blurry & choppy. Im currently using
    Mainconcept AAC (.mp4) @ 640×480 (pixel aspect ratio set at 1.000) with variable bit rate set at: Maximum – 10,000,000 and Avg. – 8,000,000. I took of snap shot of the preview. Shouldn’t the quality look as good as the preview. Is it me or youtube. I really want a clean clear upload
    Chas Smith replied 14 years, 10 months ago 5 Members · 5 Replies
  • Steve Rhoden
    May 17, 2011 at 11:13 pm
    For the best, pristine and no fuss rendering process i continually
    recommend when rendering for final output for the web, is this free
    plugin from Vegasaur called Video4YouTube…
    https://vegasaur.com/free-tools
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • John Rofrano
    May 18, 2011 at 2:01 pm
    [Shawnie Jones] “Im currently using Mainconcept AAC (.mp4) @ 640×480 (pixel aspect ratio set at 1.000) with variable bit rate set at: Maximum – 10,000,000 and Avg. – 8,000,000.”
    I have found that the “Internet…” templates under Sony AVC give the best quality for YouTube. That is what they are designed for.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chas Smith
    May 18, 2011 at 4:53 pm
    I’ve had good results with WMV rendering to 1280X720 HD @ Best setting.
  • Davd Keator
    May 21, 2011 at 2:27 am
    Sony avc internet 720p everytime… just select your proper frame rate. 1080p. Toooooo slow even with broadband Turbo :-/
    President: http://www.VertexMedia.com
  • Chas Smith
    November 23, 2011 at 3:59 pm
    Steve: Thanks for posting the Video4YouTube info. I’ve found it to be a real time-saver and snap to use. The only thing I’ve run into however is that when uploading higher-quality renders (720p+)… I seem to get Error / Upload Aborted messages after the file supposedly get’s uploaded. When I check the YouTube account, the file shows up but as an unprocessed video.
    Have you run into that issue and if so, any workarounds? Most of the lower quality renders (480p and less) get uploaded without problems.
    Could be my ISP is flaking out but the status bar shows the progress go to 100% uploaded and then Error/Abort message.
