Activity Forums Adobe After Effects the ‘Back’ of a flat image
  • the ‘Back’ of a flat image
    Posted by Kurisuta Vd wilk on January 7, 2013 at 12:16 am
    I have a composition in 3D where I want to fold an object/flat illustrator layer.
    I will do this by copying the layer and with masking different parts of the same object.
    But I want the ‘back’ of the object to be one collor, the front has text on it. And with folding you will see parts of the back.
    Is there a way to do this without making extra layers?
    because this folding effect with extra layers behind the object, is getting distorted by moire and weird lines. So I hope there is a more simple solution.
    Thanks in advance ! krista
    No knowledge is a Statement
    Kurisuta Vd wilk replied 13 years, 8 months ago 3 Members · 3 Replies
  • Darby Edelen
    January 7, 2013 at 1:00 am
    You’ll have to use a front and a back layer. You can parent the back layer to the front layer, rotate the back layer 180° and apply this expression to the opacity of both layers:
    https://motionscript.com/design-guide/invisible-facing-away.html
    This will hide whichever side is facing away from the camera so you won’t get that z-buffer interference pattern.
    Darby Edelen
  • Herbie Humperdink
    January 7, 2013 at 1:05 am
    Do a search for “Two-Sided Layer” after effects script. I think it’s free
  • Kurisuta Vd wilk
    January 7, 2013 at 1:26 pm
    Perfect !
