Activity › Forums › Apple Final Cut Pro Legacy › “the application final cut pro has unexpectedly quit”
  • Matt Goldschmidt
    July 9, 2005 at 7:14 pm
    here is more info….
    it crashes during the loading audio filters
    a bit of info – I have 4.5 loaded, I have a client that uses 4.0 (and she will not upgrade) So I loaded 4.0 Friday on my laptop – it and 4.5 worked fine. 4.5 still workes fine, I now have the above problem with 4.0. I did not know that you could load two diff. versions – but you can (and other editors have stated that they have as well with no problems)
    So… what could be wrong with 4.0? I hope that (above) info will help you to help me
    HELP
  • Walter Biscardi
    July 9, 2005 at 9:48 pm
    in order to help folks on this forum, it’s most helpful to fill out your profile, especially your entire computer system(s) information. You can view my profile as an example.
    I have no advice to give unless I have an understanding of your entire hardware and software setup.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Matt Goldschmidt
    July 9, 2005 at 10:40 pm
    mac x 10.3.5
  • Profesor
    July 11, 2005 at 12:47 am
    I have the same exact problem. FCP 4 quits while loading audio filters.
    Log report says “kern_protection_failure”
    What can i do???
  • Matt Goldschmidt
    July 11, 2005 at 3:26 pm
    I got mine fixed. There was a conflict with my web cam – I unplugg, it worked. It must have been trying to see it as a deck.
