Activity › Forums › Apple Final Cut Pro Legacy › The amount of Ram to install
  • The amount of Ram to install
    Posted by John1 on July 4, 2005 at 7:03 pm
    I’m specing up a G5 system to do heavy video intensive work. If I were to install 8 gigs of ram , would FCP make use of all of it or does it have a ceiling?
    J
    John1 replied 21 years, 2 months ago 3 Members · 4 Replies
  • David Bogie
    July 4, 2005 at 7:58 pm
    No, but it doesn’t seem to matter much. FCP currently only sees 2 gigs but that’s not to say your other apps wouldn’t benefit and FCP5.5 or 6 might change all that.
    bogiesan
  • Jerry Hofmann
    July 5, 2005 at 2:04 am
    Well I have to correct bogie (which isn’t very often) FCP 5 will address up to 4 gigs, but rarely uses that much… Motion 2 however will address all you can give it… It’s nice to run multiple apps, and do multi tasking… so the more the merrier I’d think. If you restrict yourself to 1 gig chips though, you could start with a couple or 4 gigs and see if you feel adding more would help your workflow… you can always add 2 more gigs at a time.
    Jerry
  • David Bogie
    July 5, 2005 at 4:44 pm
    Ah, yes, 4 gigs. I think I was supposed to know that.
    Thanks, Jerry. My mistake.
    bogiesan
  • John1
    July 5, 2005 at 9:03 pm
    Thanks that’s great info.
    J
