Activity Forums Adobe Premiere Pro the amazing disappearing Quicktime — exported movie file disappearing when complete. what gives?
  • the amazing disappearing Quicktime — exported movie file disappearing when complete. what gives?
    Posted by J. a. Losi on November 30, 2006 at 5:20 am
    This has been making me crazy for 2 days, and I don’t see anything about it on the forum…
    I’ve tried Export to Movie 5 or 6 times now to make an uncompressed quicktime of a 14.5 minute project. Once it starts rendering, the file appears on the external HD and grows bigger over time. Then, when it reaches 100%, it disappears!
    What am I doing wrong? I’ve tried it with timeline bars locked and unlocked, Entire Sequence and Work Area only, and nothing works. Most recently, my settings were:
    Export
    Video and audio
    Work area only
    Filetype
    QuickTime
    Video Settings
    Compressor: None
    Frame size: 360h 240v (0.900)
    Frame rate: 29.97 frames/second
    Pixel Aspect Ratio: D1/DV NTSC (0.9)
    Fields: Lower Field First
    Audio Settings
    Compressor: Uncompressed
    Sample rate: 48000 samples/second
    Channels: Stereo
    Sample type: 16-bit
    What insanely obvious thing am I missing here? I know I made QT’s of this when I was working on the project, but now several months later I’ve lost my touch. Please help!
    V
    Frankb replied 19 years, 7 months ago 3 Members · 4 Replies
  • J. a. Losi
    November 30, 2006 at 8:02 am
    By the way, I can create clips but not the entire movie. I also have more than 120 gigs of space on the drive.
  • Mike Velte
    November 30, 2006 at 12:24 pm
    What file system does the external drive have?? FAT 32 or NTSF? You need NTSF for files over 4 GB.
    Just curious, why would you export a 360 x 240 uncompressed file?
  • J. a. Losi
    December 1, 2006 at 12:25 pm
    Hey, it’s NTFS with 120G free and my main system has 39G free (it should be a 22G-25G file when done).
    That time I exported at half size so it would go faster so I could see if it would work — I’ve tried several time since at half and regular size but to no avail. Clips are exporting, just not the full movie…
  • Frankb
    February 10, 2007 at 2:55 am
    I’m having exactly the same problem. Did you ever find a solution to this?
    -Frank
