Activity Forums Adobe After Effects The 100: Opening Credits. How to ?
  • The 100: Opening Credits. How to ?
    Posted by Jp Brochu on December 20, 2014 at 6:00 pm
    I would like to achieve something similar to the opening credits of « THE 100 » TV series. Not the whole thing, but simply the effect on the letters of the names.
    Example here: https://www.youtube.com/watch?v=bFa7_OK5vFQ
    Does anybody have a rough idea how to achieve this?
    Thank you!
    Jp Brochu replied 11 years, 9 months ago 4 Members · 4 Replies
  • Helena Masterson
    December 21, 2014 at 6:47 pm
    I just tried a rough test and got a similar effect by converting text to masks to animate in sections of the letters, then added the griddler effect. Knocking the rotation by +1.0º gives it the offset look and then play around with the text opacity. Only did a quick test but hope this helps!
  • John Cuevas
    December 22, 2014 at 12:49 pm
    I was able to achieve something close to the effect using fractal noise + mosaic in a precomp to drive a displacement map effect on the text. Obviously, my attempt needs some refinement, but it might be a good starting point for you.
    8322_100sampletext.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Richard Garabedain
    December 22, 2014 at 10:47 pm
    Your best shot is a real 3d program. Even element should be able to do something similar.
  • Jp Brochu
    December 23, 2014 at 2:51 pm
    Thank you so much for your help! I’ll have a look asap!
