Activity Forums Audio Thanks Matte and Ray
  • Thanks Matte and Ray
    Posted by Robin Probyn on September 29, 2006 at 7:20 am
    Hi there
    Re the mixer hum.Had the mixer ground checked and all was ok.After setting up for test with all cables etc the mixer hum is coming from the CRT field monitor.But only when its very close ,like 6inches away or so,and goes at about 2ft,and when mic cable was very close.
    The mixer place told me that will happen with any mixer and its a characteristic of CRT monitors.Iam not the soundguy,as you can guess Iam sure,just that the guy I was working with didnt say this.
    Is it because he didnt know,or the mixer place is giving me a snow job? had same hum off another mixer of the same model at rental place.
    But anyway thanks again for your time
    Robin Probyn replied 19 years, 11 months ago 2 Members · 4 Replies
  • Bouncing Account needs new email address
    September 29, 2006 at 10:01 am
    Any audio operator who doesn’t know about “sync buzz” coming from close proximity to a monitor, or who does not FIRST check for hum by moving cables and other gear away from possible noise-generating sources, does not have much practical experience.
    If its not THE first thing you learn the first morning in
    “Audio Trouble-shooting 101”,
    its certainly the first thing you learn after lunch-break the first day. 😉
    But now that YOU know, you will never forget it.
  • Robin Probyn
    September 29, 2006 at 11:35 am
    haha well he did sort of know I think….but thought it was a grounding problem….which I last had aged 12 after pulling the head off my sisters doll.
    Anyway yes next time it happens I,ll move the monitor!!
    What is the actual technical reason for this?…in a form that idiots can understand
    Your servant
    September 29, 2006 at 2:45 pm
    In a CRT monitor, here are high-frequency circuits and “electromagnets” (coils) that create the “sweeps” of the electron beams which scan the image onto the front of the CRT.
    Any kind of electromagnetism generates Radio Frequency (RF) fields that can “get into” cables and gear that are within a given range of these.
    Lighting dimmers and even just the AC extension cords used in the shoot can radiate hum into mics, cables and other gear.
    Careful placement of all cables, etc. should be SOP on a shoot.
  • Robin Probyn
    September 29, 2006 at 4:19 pm
    Ok thanks for your time
