  • Posted by Peter Ventresca on September 6, 2009 at 5:48 pm
    Thanks for the responses. I figured it out by selecting in the “Output Module Settings” under the Video Output settings. For “Color” I selected Straight (Unmatted). Then, for “Channels” I selected RGB + Alpha. When i brought the resulting avi file into Premiere pro, it superimposed properly and achieved the desired result.
    If any of you have time, again, what does the “alpha” truely mean in regards to color, etc.
    I’ll google it regardless. thanks again.
    Peter Ventresca
    Videographer / Editor
    Frozen Sight Productions
    Frozensight.com
    Todd Kopriva replied 17 years ago 2 Members · 1 Reply
  • Todd Kopriva
    September 7, 2009 at 1:09 am
    from “About alpha channels”:
    “Color information in After Effects is contained in three channels: red (R), green (G), and blue (B). In addition, an image can include an invisible fourth channel, called an alpha channel, that contains transparency information. Sometimes, such an image is referred to as an RGBA image, indicating that it contains an alpha channel.”
    Also, Aharon has a good explanation in “What is an alpha channel?” here on the COW:
    https://podcasts.creativecow.net/multimedia-101-podcast
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
