Activity Forums Blackmagic Design Thank You Black Magic
  • Thank You Black Magic
    Posted by Shane Chadder on December 16, 2005 at 10:58 pm
    Thanks so much for the Decklink fixes in the 5.3 Multibridge drivers!!
    It fixed the problem with Decklink HD Pro cutting to DV from Uncompressed (or vice versa I’ve lost track). It has also corrected cutting from uncompressed to DV in a DV timeline.
    Now about the remaining major bugs….
    1) Huge HShift on SDI input in a BM-DV project (started with 5.2.2, 5.2.1 was fine with Premiere). 8 bit projects are fine.
    2) DV field reversal on render in 8 bit NTSC project. Here’s how you can fix this! Allow a 480 line 8 bit project! (It currently works but you can’t capture SDI in within the project, only DV.)
    And a request!
    please add HDV monitoring from Premiere…
    Shane Chadder replied 20 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
