Activity › Forums › VEGAS Pro › TGAs transparency to AVI
  • TGAs transparency to AVI
    Posted by Enrique Orozco on September 28, 2006 at 11:53 pm
    I have 600 TGAs for an animation that I want to convert to an AVI with transparency…
    1.- When I got the TGAs in timeline I have to go to each individual clip to change media properties to straight …in order to get the required transparency ….
    2.- Is there a way to select all (600) media properties to change this setting ?..
    If I render the TGAs without changing this setting, the resultant AVI (uncompressed render) doesn’t show transparency (even changing his media properties)….
    any suggestions ?
    EOR
    Enrique Orozco replied 20 years ago 4 Members · 6 Replies
  • Brian Scott
    September 29, 2006 at 12:16 am
    AVI files have no alpha channel (transparency). You will need to render to Quicktime if you need a single file with an alpha channel.
    The only way to change all the settings in through a script.
    Brian Scott
    President
    Image Design Productions, Inc.
  • Enrique Orozco
    September 29, 2006 at 12:37 am
    I’ve made 32 bit-AVIs with transparency from other (TIFF & PNG) formats …. my problem is with these TGAs that doesnt come with transparency until I change the media properties….
    EOR
  • Timothy Duncan
    September 29, 2006 at 2:53 am
    If your TGA files are for animation (1 frame per file) and they are named in numerical order, then you should re-import the files as an image sequence so you are only dealing with a single clip to change the alpha channel properties.
    I prefer using the “file open” method, as this opens properties automatically allowing you to set the alpha appropriately. So here’s how: click on the track of the timeline you want to insert your animation to. Wherever the position bar is located is where the files will be placed. No go to “File” and select “open” and navigate to where your TGA files are located. Select the first file and then check the box at the bottom of the dialogue window that says “Open still image sequence.” To the right of that is also a range selection to that you could import a selection of files, such as 0-150, instead of importing all.
    Now you will automatically get the properties window opened for the new clip (which = each individual still image as 1 frame in length).
    The only other way to set the alpha for a group of files is via scripting. Excalibur does this.
    This is a weak area of Vegas. I believe that Vegas should always enable alpha channel when present — just the way .PSD and .VEG files already treat the alpha. Add this to the feature suggestion form on the Sony Media Software website. The other problem is that if you copy and paste any graphics files between .VEGs, then you lose the properties of the clips. The best way is to nest (to bring one .VEG file into another.
    Hope this helps,
    And yes — AVIs can certainly have alpha channels. Vegas can read and write 32bit uncompressed AVIs and Quicktime files.
    td
  • Brian Scott
    September 29, 2006 at 11:59 am
    I guess I’m living in the old days! I know matrox had to create 2 separate files to have alphas in an avi. What avi codecs can handle alphas?
    Brian Scott
    President
  • Edward Troxel
    September 29, 2006 at 2:04 pm
    Uncompressed AVI can handle Alpha.
    Edward Troxel
    JETDV Scripts
  • Enrique Orozco
    October 4, 2006 at 1:44 am
    Thank you all…. there is something new to learn in Vegas..
    EOR
