Activity Forums Apple Final Cut Pro Legacy Tga with Shadow
  • Tga with Shadow
    Posted by Diana Yuen on October 18, 2005 at 3:16 pm
    when i import a TGA (which is a text only )with alpha channel into FCP, once I add a shadow to this TGA in FCP directly, the TGA Text will flick? I have try flicker filter already.. but can’t fix it… Due to some reason, I can’t use Title 3D directly in FCP to place the text. Is there any other way I can solve the problem? thanks!
    Diana Yuen replied 20 years, 11 months ago 2 Members · 2 Replies
  • Chris Poisson
    October 18, 2005 at 3:37 pm
    Paradis,
    Try LiveType.
  • Diana Yuen
    October 18, 2005 at 6:34 pm
    Actually, is it a common issue with I work with TGA in FCP?
    But Livetype can put shadow on a alpha TGA, need to type in some wordings instead..
