Activity Forums Adobe After Effects tga sequence import problem
  • tga sequence import problem
    Posted by Yan on April 8, 2005 at 5:14 pm
    Hi .. i have a problem in importing .tga sequence.
    i have 30sec of .tga sequence (around 800 ++ frame) and i want to make a .avi file from that sequence. when i import back as tga sequence to AE it didn’t import. But when i import around 200frame it work. Is there anyproblem with my AE.
    The answer will be appericiate.
    thx
    Yan
    p.s- i used AE 6.5
    Yan replied 21 years, 5 months ago 2 Members · 2 Replies
  • Hans Van vliet
    April 8, 2005 at 10:38 pm
    that’s strange, I import 5000++ tga’s all the time and they work a dream. The only thing I can do is step you through the importing process. Other then that, mmm. Go to File > Import > File .. (or Ctrl+I). Then find your sequence. Click just one picture in the seq doesn’t matter where. You’ll see a box highlight down the bottom that should say “Targa Sequence” select that box. And then press ok. And it should be in.
    Oh, I just though of a possible problem. Check the names out, make sure they are sequential and it doesn’t drop out, like go .. 200, 201, 203 .. or have a different name like, blah100, blah102, blah_103, blah_104
    it’s going to see them as seperate files .. hope this helps.
    ..::hunz..
  • Yan
    April 9, 2005 at 2:24 am
    thx .. Hans. now problem solve already. what my problem is i select all the .tga sequence and import. that’s my proble. anyway now ok already.
    thx for ur help hans.
    Yan
