Activity › Forums › Adobe After Effects › TGA Sequence color is missing channel of color.
Posted by Eric Bowman on April 27, 2010 at 2:36 pmI got like 30 minutes to fix this for a client review. Afraid it’s not going to happen in time.
I rendered a TGA sequence out and when I look in the finder window the thumbnails are correct. However when I open the files into Photoshop or After Effects it looks as though the Blue Channel was not rendered. Red and Green are there. Even stranger though, is that visually it seems the Green Channel is missing because the color is very bluish-purple as though it’s mixing the red and blue channels together.
I’ve never had this issue before, and any help would be greatly appreciated. I of course have another render going right now, but I’m wondering if any of you have had this issue before.
Eric Bowman
Juan manuel Nuñez replied 15 years, 9 months ago 5 Members · 8 Replies -
Eric Bowman
April 27, 2010 at 4:55 pmI’m using CS3 version 8.0.2.27, and I did not have OpenGL turned on, unless there’s another OpenGL setting I’m unaware of. I’m talking about the OpenGL setting in the preferences > Preview menu.
I’m rendering straight to a Quicktime uncompressed movie now, just to eliminate the TGA sequence issue. I use TGA’s all the time to eliminate the need to re-render things in the event of a crash, and up until this render I’ve experienced no issue with missing color channels. The movie is looking fine so far, and the deadline was for the rough cut so we just showed them the “funky colors” version. They also just changed a ton of stuff on the video, so re-renders are in the works.
I plan on restoring the preferences in AE as my next step, and of course I’ll try a small TGA sequence again to see if it was just a fluke. I just have to let the current render finish prior to messing around with it.
Thanks for the info, and if you think of any other issues that may or may not contribute to missing color channels let me know.
Eric Bowman
Steve Roberts
April 27, 2010 at 7:48 pmIn the “spin a dead chicken three times around you head and it’ll work” category, try rendering to a different drive. Sometimes I’ve fixed odd TGA issues by doing that, defragging, or making sure that 24-bit is selected, not 32-bit (if that applies) … weird stuff like that.
Eric Bowman
April 27, 2010 at 8:33 pmIt was definitely off. Very weird as to why this happened. I render to TGA sequences weekly and have never had this issue.
Eric Bowman
Eric Bowman
April 27, 2010 at 8:36 pmI was rendering 24bit as I didn’t need the alpha. How strange. I’m about to try a new TGA render and will let you know if things are pear shaped or not.
Eric Bowman
Walter Soyka
April 27, 2010 at 8:50 pmThis is not really an answer to your question — but does it have to be Targa? I’ve found that TGA files can be a bit touchy — different software packages have different preferences on byte order, compression, etc. This is also true of TIFF, which I’ve heard referred to as “Thousands of Incompatible File Formats.”
PNG might be another option. Like TGA, it’s lossless and supports transparency.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Andy Clarke
May 17, 2010 at 12:05 pmI’m experiencing this issue too. The blue channel is solid white, which is maximum blue, thats why the image is all tinted blue even though the blue channel has no image information.
I’m not sure why. If I include the alpha channel (even though i dont need it) the blue channel renders normally.
seems like a bug. no logical reason i can see why the blue channel should render solid white?? -
Juan manuel Nuñez
September 3, 2010 at 5:03 pmI’ve been having the same problem with AE and tgas, and also, I’ve done tga secences without problem before. Suddently it started adding this full white to the blue channel.
The solution to me was, like Andy here, Adding the alpha channel to the render.
Maybe it’s a weird bug, and when you set it not to render the alpha, it removes blue channel instead of the alpha inserting the alpha on it.If anyone knows the real technical problem here, i would like to know =)
thanks everyone!
Juan manuel Nuñez
December 16, 2010 at 2:57 amThe error seems to appear when you render a TGA image secuence without alpha channel and set at 32bit/pixel resolution (in the format settings)
If you need to render a tga secuence without alpha information, you have to select 24bits/pixel, in order to have it rendered without the blue channel afected.
