Activity › Forums › Apple Final Cut Pro Legacy › TGA import in anamorphic (16:9)
  • TGA import in anamorphic (16:9)
    Posted by David Winters on May 9, 2005 at 5:44 pm
    Is there a way to set FCP’s default TGA import setting to apply the anamorphic pixel ratio?
    I’m working on a project with TGA stills and text builds. Could be several hundred images. TGAs are 720×480 (NTSC) composed for 16:9.
    Currently I’m clicking on each image, in the bin, and applying the pixel ratio. Wish I could select a group of clips (TGA’s) and make the change. They are not image sequences.
    Chris Poisson replied 21 years, 4 months ago 2 Members · 1 Reply
  • Chris Poisson
    May 9, 2005 at 6:22 pm
    David,
    Can you try applying the distortion to the first file and paste attributes to the others? FWIW, I make all graphics for anamorphic projects at 864×540.
