Activity Forums Adobe After Effects TGA files to time line in formation
  • TGA files to time line in formation
    Posted by Martin on March 23, 2006 at 11:59 am
    I have a bunch of TGA files that I want to make a animation from. How do I get the files to form a step formation on the time line?
    Martin
    Martin replied 20 years, 6 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    March 23, 2006 at 9:44 pm
    Are your TGA files a sequence? As in each TGA is a single frame of the animation. If so, when you import the files, choose only the first file (this is assuming they’re numbered sequentially), then check the numbered Sequence box at the bottom of the Import dialog. AE will them import the footage as a single movie file.
    If that’s not your goal, use Animation > Keyframe Assistant > Sequence Layers. I think it’s only in AE Pro.
  • Martin
    March 24, 2006 at 3:32 pm
    Thanks for the info Timothy. That worked fine.
