Activity Forums Boris FX Particle Illusion TGA file sequence into Vegas
  • TGA file sequence into Vegas
    Posted by Craig Cooper on April 22, 2007 at 2:25 pm
    I have outputted a sequence from PI to TGA files as per Elvis Deans suggestion. When I call them into Vegas I can’t get them to display under a second for each picture.
    What is the correct procedure to do this?
    Craig
    Craig Cooper replied 19 years, 4 months ago 3 Members · 3 Replies
  • Elvis Deane
    April 23, 2007 at 5:32 am
    Check the bottom section of this tutorial, marked “From particleIllusion to Vegas”
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • Accountclosed
    April 25, 2007 at 2:45 am
    Do you check the bottom box in Vegas Media import to read the whole sequence? When unchecked, only one frame will play (the second you mentioned 🙂 This also applies to PNG files.
  • Craig Cooper
    April 25, 2007 at 6:21 am
    Yes. I checkboxed “open still image sequence” then select the frames I need.
    I’m sill playing around with the “Alpha” settings as I’m not sure the differences between them.
