Activity Forums Adobe Photoshop tga – alphachannel
  • tga – alphachannel
    Posted by Gunnar Kordestani on February 7, 2008 at 6:28 am
    hello everybody,
    I have a cutout in a photo here, the rest around is transparent.
    To further use it in dps velocity I want to save it as a tga file. What is the trick to get an alphachannel that uses the transparent parts.
    when I save as tga and then open the file again in PS (CS2) the alpha channel always is pure white. In the ‘save as’ dialog I can’t click the ‘alpha channel’ checkbox (it’s there, but not available).
    Maybe I need to say ‘add layer mask > reveal selection’. This gives me a mask, but I don’t manage to make this an alphachannel.
    thx for your help …gunnar
    Gunnar Kordestani replied 18 years, 6 months ago 2 Members · 2 Replies
  • Ekim Wahs
    February 7, 2008 at 5:32 pm
    To get Targa with Alpha versus Transparency you need to use the Photoshop 7 plug-in. In Photoshop 7 Targa was changed to use alpha instead of transparency, but we got a huge number of complaints about the behavior change and had to change it back in 7.01. The plug-in will work in later versions of the application. If running CS3 on Leopard it requires running under Rosetta to get the plug-in to work. If you are using CS3 you can also use Render Video and render a QuickTime Targa image sequence of a single frame to get the desired behavior.
    Windows:
    https://www.adobe.com/support/downloads/thankyou.jsp?ftpID=1544&fileID=1478
    Mac:
    https://www.adobe.com/support/downloads/thankyou.jsp?ftpID=1543&fileID=1477
    Mike Shaw
    Photoshop QE
  • Gunnar Kordestani
    February 11, 2008 at 5:17 am
    hm, the thing I was looking for I finally found myself by just clicking the “new mask” (or so) button in the bottom of the “Channels”. Then ‘save as’ tga > alphachannel > 32 bit…. (CS2 here by the way)
    Now I am a little confused about what you are talking here….
    thx anyway
