Activity Forums Maxon Cinema 4D Texturing Question (Football Helmet)
  • Texturing Question (Football Helmet)
    Posted by Jeff Klein on August 10, 2011 at 10:02 pm
    Hello. I’m trying to get the following texture onto a model of a football helmet shell, and can’t get any of the projection methods to work the way I need them to. The pattern of the texture does not need to be exact, just close. I’ve gotten it to look OK on certain parts of the helmet but never correctly on the whole helmet at once. Any suggestions would be greatly appreciated. Thanks.
    Here’s the texture…
    https://tinypic.com/r/ve7sk2/7
    Here is what the helmet needs to look like…
    https://tinypic.com/r/2zzkojr/7
    Steve Blacker replied 15 years, 1 month ago 2 Members · 7 Replies
  • 7 Replies
  • Steve Blacker
    August 10, 2011 at 10:27 pm
    Can you post an image of your attempt so far? Might help to see where the problem is.
    Looks like spherical mapping should work.
    It’s only work if you’d rather be doing something else…
  • Jeff Klein
    August 10, 2011 at 11:06 pm
    Hey Steve, thanks for the response. Spherical mapping looks OK (with some tweaking) from certain angles, but it gets screwed up on the top of the helmet (the pattern gets smaller and comes to a point). Here’s what it looks like…
    https://tinypic.com/r/35bh6b4/7
  • Steve Blacker
    August 10, 2011 at 11:30 pm
    I think the issue on top of the helmet is related to the mesh there – if this helmet was started from a regular sphere you’d get that issue.
    How about using UVW mapping and the texture tool to play with scale and positioning?
  • Jeff Klein
    August 11, 2011 at 12:04 am
    Main problems is I can never get all the “checkers” to be a uniform size throughout the helmet. UVW map still runs into problems.
  • Steve Blacker
    August 11, 2011 at 12:54 am
    Hmmm. Cubic doesn’t work either? Can you upload the model file and texture?
    p.s. Is this for a still or animation?
  • Jeff Klein
    August 11, 2011 at 1:35 am
    Nope, cubic doesn’t work either. This is for an animation. Here is the helmet C4D file and texture, I only included the shell of the helmet to keep the file size down (and this is the only problem part which needs the texture). Thanks and let me know if you have any luck.
    https://www.closertoinfinity/_transfer/misc/helmet.zip
  • Steve Blacker
    August 11, 2011 at 11:38 am
    Seems to me that the mesh is a bit messy, so the texture is not being applied correctly. Do you have a lower poly version of the helmet?
