Activity Forums Maxon Cinema 4D Texturing Packaging
  • Texturing Packaging
    Posted by Donald Mitchell on August 8, 2006 at 12:00 pm
    I have a project where I need to make a photo realistic render of a presentation box for a bottle of Vodka. I have modelled the box top using a cube primitive with slightly filleted edges. I am trying to get the flat artwork that was used to print the actual box to wrap round my model so that the front, sides top and bottom all look right. I can’t seem to figure out how to do it. Using UVW mapping I can get the front right, but not the sides, top and bottom. I could apply different textures to different polygon selections, but then the texture doesn’t run over the filleted corners properly.
    Can anyone help or point me in the direction of a comprehensive tutorial?
    Thanks in advance,
    Mitch
    Bmissen replied 20 years, 1 month ago 2 Members · 1 Reply
  • Bmissen
    August 9, 2006 at 10:12 pm
    Mitchino,
    I have run into the same trouble as you have. I solved it the same way you are attempting to, by flat mapping sides onto selections.
    I have been succesful by selection mapping on a sharp edged cube and then using the nurb weighting on the edges to make it nice and rounded. I start with a 6 sided box map in photoshop to get the overlap right, it looks like a cross. I then cut it down into individual sides (this is so I can take advantage of the fit to region command). I set my selections, flat map each side onto the box. I then switch the map mode to UVW to get it to deform when I soften the edges. I then use the edge selection tool to grab the edges that I want to soften. Once the edges are selected I set the NURBS weight by holding the period key (.) and dragging left or right in the viewport. I’m not sure this is going to work for you, but it’s worth a try because it’s quick.
    I have also tried using bodypaint, but I get too frustrated and impatient. I try to avoid it if possible. It works great if you have it and have the time to do the tute to get you up to speed.
    I don’t know if any of these options are going to be applicable or useful. Hopefully they will help.
    Cheers,
    bmissen
    none of us is as smart as all of us
