Activity Forums Maxon Cinema 4D texturing issue
  • texturing issue
    Posted by Tom Ma on March 24, 2011 at 8:48 pm
    I am trying to texture a sweep nurbs object. It is basically a ribbon shape that I need a graphic to slide along.
    I am texturing it using UVW mapping.
    Problems:
    I cannot orient the texture correctly. It is on it’s side, (although the image I am using is correct orientation)
    Also, the image has an alpha channel, and that is reading correctly on the object, but any area where the graphic is not placed, is visible.. I would like it to be transparent.
    any help would be appreciated.. thx
    Tom Ma replied 15 years, 5 months ago 2 Members · 2 Replies
  • Brian Jones
    March 25, 2011 at 3:24 pm
    Orientation – either rotate in PS before import or put the image in a Layer channel and apply a Transform Effect to rotate it 90° there.
    Alpha everywhere – make a material that is 100% transparent (or alpha) and add that to your ribbon. The 100% transparent needs to be first (left) and the graphic second (to the right in the tags)
  • Tom Ma
    March 25, 2011 at 7:16 pm
    fixed. thx!
